robgommans
So...
It started with water leaking from somewhere around the oil cooler. I replaced the o-rings front and back (water intake/outtake) and it stopped leaking, but now it was leaking from the cooling pipe entering water in the oil cooler. I sealed it with liquid sealant. Problem solved...at least in terms of leaking water.
Next day when for a ride...upon return, port side of engine room completely covered in white slush. The ride went fine, the only thing was that it became very hot apparently based on my temperature gauge. So I gave it a break before returning to port.
My guess...it could be a blown head gasket, a cracked head (hope not), a failing o-ring behind the impeller, or a failing (leak) oil cooler. Since the oil cooler was giving the problems in the first place, started with that.
Bypassed the oil cooler completely with a hose connecting directly between water pump and manifold. Changed the oil now for the third time. 2nd time oil still looks a bit milky, but not as much as the 1st batch. We'll see what the oil looks like tomorrow. Had the motor run warm before changing the oil and rinsed the inside with a bit of diesel as well. Maybe we need at least 3-4 oil changes for all the water to come out.
I also took off the oil cooler today and tried to blow through the water inlet, while blocking the water outlet. Couldn't...so my guess is, the little water canals inside the oil cooler are not leak. Am I drawing a most likely correct conclusion? No air appeared to be leaking out of the oil canal. Of course, I have no idea how much psi I can blow and how much psi is normally put on there.
So...if the oil cooler appears to be ok...what then caused water to go in the oil? Providing that there isn't any water coming in the oil right now anymore. Not fully sure that is the case. Will do a compression test tomorrow and check the waterpump. I haven't really stress tested the engine yet. Maybe that is also something to have a look at...
Any tips, ideas? Your help is really appreciated.
Ps. I left the oil cooler out for now (that is bypassed, oil is not cooled at the moment). Not sure whether I really need to reinstall it eventually...the oil doesn't feel very warm when I ran the engine for about 20 minutes at 1000 rpm and shortly 1-2 minutes at 3000 rpm.
