G
GregLipski
Guest
" I have a mastercraft with an
" I have a mastercraft with and inboard 350. On its last day of use last season, it was exhuasting steam and ran a high temp. When I brought it home getting ready to store for the winter, I saw the familiar brown sludge oil. I changed the oil and ran it for a couple minutes. Yesterday, I started it up on the trailer and it ran nicely at idle, but when I sped it up (2500rpm), steam came out of bothe exhuasts and I saw the brown foam from the oil add cap on the valve cover. I drained the oil and about a quart of water came out with the oil. I noticed a slow leak at the mating surfae between the starboard exhuast riser and the block. Can exhuast riser corrosion or leaks lead to water in the oil? Since both sides steam, is that a problem when running on the trailer or is that normal as the exhuast would heat up the cooling water? Any and all help is appreciated. I tend to not suspect a cracked block or head since this first occured before the winter season last year. Thanks. "
