1979 20’ Tiara cuddy cabin
1979 OMC 800 Series stern drive
New engine about 4 or 5 years old 350 5.7 Chevy 260 hp
The whole stern drive has been replaced with an OMC 800 series (1982 +), after hitting a sand bar and braking the old stern drive. While replacing the stern dive (did it myself) I only removed the risers from the engine did not touch anything else on the engine. After putting the boat back together I took it for a test ride. When returning from the test ride I removed the engine cover and noticed milky muck on top of the carbonator that came from the hose of the valve cover. Of course water is getting in the oil. The engine is running great. I have replaced the oil and filter 5 or 6 times. I removed the intake manifold and see no indications of water leak. Removed the heads and had them tested the showed no defects. The cylinders showed no rust or water. Had the risers and exhaust manifolds tested with one exhaust manifold showing a leak. I replaced all gaskets for heads, risers, exhaust manifolds and intake manifolds. Also, put all NEW risers and exhaust manifolds on. I am still getting water in oil (milky oil coming up to the rockers) and the engine runs great. Have recently performed compression check and that shows all cylinders have a compression of @ 120. I have not had the intake manifold tested or replaced.
Did a pressure check in all cylinders as recommended by a friend. Removed plugs and applied air pressure to cylinders and check for bubbles in the area of thermostat hole with thermostat housing removed. No indication of bubbles in any cylinders.
Would you have any suggestions of where the water could be coming from or what I can check next?
