"I had an exhaust manifold cra
"I had an exhaust manifold crack on my GM 4.3 Liter Vortec motor. As a result, water can into the left exhaust port of my motor and seeped into the motor. THe oil is all milky colored and doubled the volume of fluid in my motor (as observed by the dip stick). What is the best way to clean out the water? Are there issues I should be worried about regarding the water doubling the amount of oil in my motor? I discovered the milky oil while leak checking my new exhaust manifolds (it was leaking out of some unknown area of the motor and my pressure indicator was bouncing from 20 psi to 70 psi then to 0 psi and then back to 20 psi."
