tom_barker
"I think that I finally finish
"I think that I finally finished working on this old 62 Johnson 10 hp because I had it running in a feed tank for several hours over the last few days--tonight I broke down the set up and emptied the feed tank thinking I was all done--went out just before dark and low and behold there is a small puddle of a grey/beige thick liquid on the ground under the motor and there are two places where it is leaking out around the cavitation plate--there appears to be two small holes in the casting of the lower unit--one on the underside of the cavitation plate and one at the casting seam where the lower unit seperates from the exhaust housing--the hole at the casting seam is ABOVE the top screw that is removed for changing the lower unit lube--so I figure either water is getting in the lower unit or I have the wrong lube, which is expanding and ozzing out--i have some pictures if that would be helpful--any ideas would be appreciated. tnx tom"
