bocephus101
Hello have a 89 Evinrude 50hp E50BELCIC was leaking oil from around prop and exhaust area replaced the prop shaft seals getting water in lower unit oil then removed lower unit had a guy check the unit he said he replaced a seal. Still getting oil in lower unit. I did a pressure check of unit put 15lbs on and it held the pressure at least 10 minutes. I replaced the drain screws washer seals put new oil in and now it still gets water in oil. No oil or such is coming out prop or around prop the exhaust area is clean looking no oil leaks anywhere motor starts and runs great idles good. Where can water be getting in oil now?. Thanks
