Water in intake VPAQ260a280
after replacing:manifolds&risers,heads&gaskets,water pump impeller took a test run and it shut off again all the cylinders were full of water and i also wate"
"Both banks???? Check to see i
"Both banks???? Check to see if the flapper valve in the exhaust port above the prop is stuck. Or if that version does not have one, that the internal flaps in the exhaust bellows are ok (and facing the correct way)... or that there aren't barnacles or other critters blocking the exhaust port."
