Water in gear oil
rickroot
"took my 1985 merc 3.0L (1
"took my 1985 merc 3.0L (140hp) w/Alpha One (original) stern drive out Friday evening for a test run finally after all the work done on it (discussed elsewhere... but basically replaced stern drive water pump, engine circ pump, AND thermostat).
When I filled it up with gear lube there was no apparent leak, nor after running it for 20 minutes or so on the earmuffs.
I spent about a half hour or so out on the lake Friday night tooling around. It ran great. Better than ever, actually. The next day I noticed an oil leak out the weephole in the lower unit.
I have not yet taken it apart but I did drain the oil today and noticed the telltale streaks in the oil which I understand is an indication of water in the oil.
When I take it apart, I guess i need to check these things again:
#1 - the oil passageway seal
#2 - the upper drive shaft o-ring
what else? the drive shaft goes up through an oil seal in the upper unit right? That's one thing I never really checked.
What about the shift shaft?
Dad and I had a really hard time getting the lower unit back on the last time we put it back together."
#1 - are you talking about the
#1 - are you talking about the quad ring seal on the cavitation plate? That would be a source if it did not seat properly.
"You really should pressure te
"You really should pressure test the drive with 10-15 psi air pressure. That will find any leaks.
The shift shaft seal is a prime suspect, as is the upper and lower drive shaft seals. The quad seal should also be checked.
Rod"
