chriscraftcat
"I have 2 crusader 305 engines
"I have 2 crusader 305 engines which ran fairly good every time I started. The last start up was three days ago when I ran them for about 5 minutes each in the dock, at idle. Boat has been in the dock for the last two months because of the repairs/replacement of the cooling hoses, boat repairs, etc..
Yesterday, I tried starting up both engines but could not do it. I used some starting fluid and it fires each time (to confirm that electrical system is OK).
I took off the fire prevention covers and noticed both carbs are corroded heavily. The accelerator pump shaft were rusted and hardly moved. After loosening them I pumped the fuel in and still could not start the engines. When I took the gas lines off I noticed water mixed with gas. I removed one carburator and found mostly water inside.
I will rebuild both carbs, but now I must syphon the gas out of the gas tank. There is about 50 gal in, and tank holds 125 gallons. How do I do it safely in the dock? Should I remove the boat and then do it on dry dock? My boat is 1988 Chris Craft Catalina. Please help.
Gene"
Gene"
