"I have an '88 open bow ba
"I have an '88 open bow bayliner 3.0 that appeared to have soft spots of wood on the floor aound the center walkways and behind the seats. I pulled the seats and took up the carpet and found that someone had previously placed 3/8" plywood over the existing floor. Most of this was rotten, so I pulled that up also, thinking I could easily replace that and have a new sturdy floor. Under that was the original floor that appeared to be at one time covered with a thin fiberglass coating. It had many cracks in it and appeared to to be also waterlogged and weak. I took a 2" hole saw through it into the foam to check, and the foam appears to be waterlogged. this is on both sides of the tank running front to back. Is there any way to dry this out and recover and reseal it? Or do I need to pull it all out and refill with foam under the floorboards? I have the seats all out and it is very easy to get to, but I need some ideas on which was to go from here. thanks for your help..."
