"One thing after another,
I
I have a 94 5.0 LX Mercruiser, just purchased and went thru and changed oil and did a tune up, The timing was off and motor was cranking hard, I adjusted the timing to be correct and the motor cranks good and motor starts right up, When I was doing this it seem the motor was running Hot by the gage temp ? I had a garden hose hokked up for cooling the motor and seemed fine? Today I went and checked the motor oil to see how the level was and Now it looks like there is water in the Oil? Now What? When I changed the oil it was good with no water, How do you determine if a head gasket went out or if the block may of cracked or could it be something else?"
I
