Hi Guys
Just looking for some advise , over the weekend we where runing the boat which I might ad ran great , until I stoped for a while and when I went to start it ,it turned over real slow like a dead battery . I thought that it was time for a battery so we where just care full and finished the day out, but when I pulled it out of the water and hooked it up to the hose to flush the saltwater out it did it again but worse then it locked for a split second while cranking . I knew by the sound it was water in the cylinder so I started pulling spark plugs out . The very first one towards the front of the boat released air presure and then I could actualy hear the water runing from the hose into the cylinder and then out the spark plug hole. So the question is , is it head gasket or exhaust manifold, what would be your gues and is the motor toast now? The motor is a 1985-86 3.0 GM with a stringer drive on it. Hopefuly some one will chime in , Thanks
