"One of my engines had water i
"One of my engines had water in a cylinder,and turned tight at startup removed plugs blown water out,put oil in the intake to and turned it over with all plugs out installed new plugs and it started and ran fine 40psi at idle 120-150 psi on all cylinders fresh water cooled manifolds look rusty on the outside should I replaced the manifolds because they look rusty mostly on the end plates what do you guys think..just to give a history just bought this boat starboard engine in question next weekend going to run this engine under the hose for a while just wondering if I should replace the manifolds or what new to inboard boat engines thanks....also motor was sitting for at least two years without being run they were moist on the outside when viewed at first the carb was so bad it was corroded shut replaced with a new 1409 after cleaning up manifold"
