I'm getting water in both cylinders on my 50hp force. It runs perfectly above idle, same top speed as usual but at trolling speed it takes coughing spells or runs on 1 cylinder sometimes. If rev it up it will be ok for a while. When I check the plugs both have a bit milky residue on them.i checked the gas and it's clean.
Can there be any other places that can let moisture in?
I'm sure it's not a head gasket cause it runs perfectly above idle and if it were it should only affect one cylinder.
