knuckle47
Advanced Contributor
"I have been trying to elimina
"I have been trying to eliminate the backfire I am getting on my port engine by systematically swapping parts from a known good source (starboard engine) and then finding the component causing the problem. Today, I switched the carbs. The starboard engine started better than the fuel injection on my 2005 Suburban ( which starts perfectly). When I went to start the port side she just cranked and cranked until it started to lock up. Having 6 gel batteries to link together I KNEW that the cranking voltages were not a problem.
I took out the # 1 spark plug and about 3-4 ounces of water poured out of the hole.
IS THERE ANY other reason besides a gasket that this might occur on fresh water cooled systems?"
