"I have an 89 bayliner w/ a 3.
"I have an 89 bayliner w/ a 3.0. Idle temp is 170, whether on the muffs or in the lake, when cruising on plane around 2800 rpm temp will fluctuate between 160 and 180. If i open it up to 4200 at WOT, the temp sometimes gets up to 200 - 220.. slowing down brings it back down to 180's. Knowing that either water is not getting in or out, I checked the water passages, manifold, etc for obstructions and found nothing. What I did find was interesting,, when I pulled the impellor, some of the impellor blades we not curved all the same way.... ie,, 6 were curved in the direction of rotation, and 3 or 4 had turned/ flipped the other way, spinning against the flow of water,,, has anyone ever heard of this? also the impellor cage was not round,,, it was more egg shaped,,, any ideas? A dealer put on this new impellor for me last year,,, but I figured with three bolts that it was easy to check and I reinstalled it with all of the blades curving the same way,,,, just not had time to test it yet...
thank you for any help or ideas...."
