Water hoses Chrysler 360
Can anyone help on which water
Can anyone help on which water cooling hoses they've had the most luck with matching the bends on a Chrysler 360 raw water cooled? It's getting expensive cutting up a brand new hose for each curve and section. I'm hoping someone has found a hose or two where at least two of the bends can cut apart and each used instead of so much waste.
"i had to replace mine and too
"i had to replace mine and took it to NAPA. they found one that matched pretty closely and i only had to do some minor trimming.
"sorry no i don't. the na
"sorry no i don't. the napa guy had a hose that was ordered and never picked up. they have a catalog with all kinds of shapes and sizes. so, if you have the old one, bring it in and they should be able to get a close match!
good luck"
"Correct! Be prepared to use
"Correct! Be prepared to use PART of some hose to make it up. Just be sure the diameter is right, and that the straight and curved part of the hose will do the trick. Hoses are cheap, so get more than one if you're not positive.
Jeff"
