"Let me start by saying that I
"Let me start by saying that I probably am in over my head on trying to fix a number of problems. I've been in an ongoing struggle with a 7.4 V8 Thunderbolt. It's been winning and has been sitting on the lift since last summer. The most recent challenge has been overheating. I changed the impeller last weekend and the old one was disintegrated. I know I should backflush the system but am not sure how to do that. Maybe from the thermostat? I've attached what I think is the correct diagram for my engine cooling system.
Actually that may be secondary. When the new impeller didn't do the trick I went back to basics and removed the seawater intake hose from the seawater pump to make sure there was water coming in. When I tried to flush by putting a hose on the garden hose flush attachment on the outdrive there was zero water from the hose. I'm thinking that's not right. True? Could sitting on the lift have caused some corrosion of the inlets? My plans was to check that idea out this weekend but like I said I'm a real rookie with this and maybe there is something more obviously wrong. I'd appreciate some guidance. Knowing what you're doing is a wonderful thing.. I guess!
Thanks...
Steve
Cooling diagram
Thanks...
Steve
