davedesmarais
Last season the water flow was more of a spray than a stream, but the engine always ran perfect, no problems at all. So I just installed a new impeller and expected a better stream, but exactly the same. I suspect some blockage in the tubing. I've tried a small wire from the outside port and a larger wire on the tube rising from the water pump while the lower unit was off. Any suggestions on how to clear the tubing? Should there be a stream of flow? Thanks
