Water dischargeWhat is normal
P
PPBBSS
Guest
"When I hook my Johnson 110 vr
"When I hook my Johnson 110 vro to the garden hose and open the tap, should I only see the small stream of water coming from the hole on the starboard side? Or are there other discharge ports? This is with the engine not running. When it is running, should anything change? Might be a stupid question but I am a newbie and my service manuals do not show anything clearly on this. Thanks Engine Model # CJ110TLCCA"
"u may,get a small stream of w
"u may,get a small stream of wtr thru the indicator.if your flusher fits real tight,..no where else until the eng runs,..it discharges water,thru the exhaust relief holes,thru the prop,and the the small holes above the cavitation plate,on ea side."
