Water coming in from the drive
I have water coming in from the drive, what's the best way to check where from?:mad:
Ayuh,.... Stick yer head in there 'n Look,.... When it's leakin' of course....
Best tip I've got is,.... Water flows downhill....
When ya see Wet, look higher, til ya see Dry.... ya just looked passed the Leak...
If it's an alpha o/d only two ways, the drive shaft bellows or the shift cable bellows. look at the back end of the engine just below the driveshaft that goes into your coupler.
same.. you have to look whether it is above or below the driveshaft. best way to find it leave the boat in the water at the dock have your trailer in the parking lot. take a flashlight and look and listen for dripping water from the engine side of the boat,after you have spotted the leak, pull the boat post back where it is :eek:
