jwkillntime
"Have 1995 Yamaha, 85 HP, 2 st
"Have 1995 Yamaha, 85 HP, 2 stroke (not oil injected) Yesterday engine shut down and would not restart. Have strong spark on each of the three cylinders. Pulled the plugs and found water around each of the spark plugs electrode. Where should I look for the cause of water around the electrode of each plug? Sprayed WD-40 in each of the cylinders, then poured 2 stroke motor oil in each of the cylinders as the engine was turned over. Did this to possibly avoid cylinders rusting to the walls.
Add Your Message Here"
