dock_holiday
"Hi fellas, I just changed o
"Hi fellas, I just changed out all the valve springs on my VP 170 motor. I put in all brand new ones from Sierra. During the swap I found 2 additional broken springs in addition to the 2 I already knew were bad. So the broken springs are as follows. #2 in., #4 in.,#4 ex. #6 in. . I cannot figure out why 4 springs would break after less than 10 hours running. These springs were used, and supposedly good on a head I bought w/ valves and springs already in it. The springs were all intact when I put the head on. I also found that each valve spring had a spacer or washer under it, sitting in the well in the head where the spring sits. These spacers were stamped "6025" and appeared to be brass or copper. They were the same outside diameter as the spring bases, same inside diameter too, and appeared to be approx 1/16 inch thickness, as if stamped or machined from 1/16 inch sheet stock. I have no idea what these spacers are for or if they should be there or not. Any help on these guys? In anycase I left them in under the new springs. I have not put the whole thing back together yet because I thought I might have to go back in and pull out the spacers depending on what I learn from you all. Could the spacers be a cause for spring breakage? IE could the spacers cause the springs to be compressed too much all the time and contribute to fatigue of the springs? Perhaps someone put the spacers in in order to sort of "shorten up" the springs to make up for poor spring rates on old worn out springs?
should I leave the spacers in under my brand new springs?
By the way, I used the "rope fed through the spark plug hole" trick to hold the valves up as I messed with the retainers and springs. (no compressed air in my shop so standard proceedure was no go.) The rope trick worked like a charm!!
Thanks for any and all help.
Matt"
Matt"
