I have in France 2 Yamaha F100 on a fishing boat length 23' beam 9' weight 4400lbs propellers 13x19.Both engines have run about 270 hours since 2004.The engines run great up to 4800rpm during hours when the boat is cruising .If I run at 5300rpm the alarm buzzer sounds and the ECU reduced the 2 engines speed but I see no visual indications on the instruments (oil and température).I reduce the throttle to the idle position without stopping the engines , and if I return to 4800rpm immediately the engines run great again .If I run one engine to 5300 rpm and left the other at 4800rpm the buzzer sounds and the ECU reduce the speed, if I change with the other engine the same think occurs. If I try without coupling the engines, both run at 6000rpm without problem. The engines temperatures looks normal.
According to Yamaha service and yamaha shop manuel the buzzer sounds if a low pressure or engine overheating occurs.
I test the 2 oil pressure switch with a pressure gauge , a vacuum pressure pomp , and a multimeter and they are OK (no continuity at 22psi),I test the both temperature sensors and the resistances are normal according the specifications but I decide to change the temperature sensors ,and thermostats on the 2 engines. One Yamaha technicien saw nothing anormal but founded that one rectifier regulator was out of order (problem well known on the engines from 2001) I change both rectifier with the new model, and the charging system is in order (14,92V at 1500 or 3000rpm) and always the same problem at 5300 rpm
New oil, filter, batteries...Yamaha France have never seen such a problem....
Is it possible that the problem comes from the throttle position sensors (on both engines ?) it seems that the ECU read an overspeed of the engine at 5300rpm but only when the boat is cruising (on both engines ?) the 2 ECU are out of order ???
The boat is equipped with the 704 remote control.
Any suggestions would be greatly appreciated
Thanks in advance PAUL
