parkjehhyun
I was always told there were no dumb questions.. but.. I feel like this will definitely make me look a bit stupid........
I've got a '95 Nissan 8HP for my dingy, but had about a 1.5 gallons of premixed 2-stroke oil/gas (50:1 ratio) that was about five months old. I added 1.5 gallons of fresh mix and noticed the engine running MUCH weaker than when it was last run five months ago.
I did compression tests and they came out to around 95 PSI for both plug holes.
Questions are;
-Will using a slight mix of slightly old fuel cause your outboard to run noticeably slower?
-Is fuel of five months even considered "old"?
-Is 95 PSI considered low? If not, should I get the outboard checked out for other issues?
Questions are;
