Warning buzzer caused by oil tank
chris
After disconecting wires at t
After disconecting wires at the engine I found that the oil tank wire was causing the buzzer to sound steadily. After taking the unit out of the tank and cleaning it stopped. Is this part something I need to replace? Thanks for any info.
" CHRIS NEED MORE INFO. WHAT K
" CHRIS NEED MORE INFO. WHAT KIND OF MOTOR,HP AND YEAR OF MOTOR MIGHT BE HELPFULL. ALSO THE COLOR OF THE WIRES YOU DISCONNECTED IF YOU REMEBER. "
Sorry 1988 120hp evinrude. Di
Sorry 1988 120hp evinrude. Disconected the brown wire at the engine. Seems to be okay now. Just wanted to know if these senders in the oil tank go bad. Doesn't look like a repairable part. One other question there is a red lever for the fogging oil hook up. Which way should this lever be in regular running position? Thanks for any help.
