"Hi all, Hope I can get some h
"Hi all, Hope I can get some help here. have a 1990 Bayliner with the above engine. Took it out for the first time in 2 years yesterday to try and impress my new partner and her daughters. unfortunately i got a contant ticking sound coming from the warning buzzer. maybe two or three a second. I checked the water outlet and that was cool and strong. The oil was also filled upoto the 3/4 mark. I decided to undo the oil pipe from the oil injection tank in case there was a problem there and manually mix the oil straight into the fuel tank in order to make sure i wasn't going to seize the engine. I assumed the mix ratio to be 50:1! Hope i was right. Boat ran fine but after 10 mins or so a much louder beep came from the buzzer which got quicker as i ran the boat a little quicker. sometimes it went off as i increased the revs then as the day went on it was beeping continuously. if i turned the engine off and then instantly restarted it would come back beeping again within 5mins. All of the time there would be a fainter ticking sort of noise coming from it too. I was constantly checking the water coolant jet all of the time which was always cool and strong and as i knew there was oil within the fuel assumed that nothing major could spoil there special day up the Tees! I really only know the basics upon the mechanics of boat engines therefore if anyone reply's please dont be afraid to think your patronising me if you explain in a very simple manner! How can i check if it is pulling up oil from the Oil tank? and could it be a faulty buzzer? How do I check that? If i meed a new buzzer, where is the best place to get one? Hope someone out there can help me. Please be patient if i don't reply on the same day as i am a shift worker and currently work,sleep,walk the dog and grab a bit of time with my partner but will find time to check on here every day! Thanks for taking the time to read this and so pleased there are sites like this to help people out who haven't got the finances to pay for Marine specialists to keep their boats afloat!! Thanks Scott. Newcastle"
