"I am trying to do a pump swap
"I am trying to do a pump swap from VRO to the standard style. I have a 92 johnson 70 hp. I have been told on this site that the 92 johnson 65 commercial pump is an appropriate swap. That part number is 0438557. Sierra and Mallory do not seem to make a pump version for this but the OMC version is still only 100 versus almost 400 for the VRO. I understand I will need to make some sort of bracket to mount the pump-I think I can figure that out and maybe use the old bracket from the VRO somehow. For this type pump is all I do is connect gas line in gas line out and line from the pulse limiter and I am done? Is the hardest part just making a bracket? Do i need to purchase anything else? I have the OMC manual but it really does not go into how the pump is mounted on the 65 commercial. Is there a 65 exploded diagram so I can see if that has a bracket I could purchase? If anyone can give me a little guidance I would really appreciate it. I don't want to order more than once, etc. Thanks all in advance."
