"My '89 Evinrude 110 VRO h
"My '89 Evinrude 110 VRO has run strong for years. It has been well maintained, etc. Over the last two years it began wanting to fluctuate rpms when running around the 4000 rpm range. Just annoying. It would hold steady rpms above or below 4000. My trusted mechanic suggested that the VRO pump may be getting weak. I asked him to replace it.
The first trip out with the new VRO the boat ran great for about 30 minutes on the way to the fishing grounds. On the way back in, about two hours later, the motor just quit when running around 4000 rpms twice. It seemed as if the fuel flow had been interrupted. When I tried to restart it immediately the battery sounded as if it had been run down. After thirty seconds or so (each time) the motor would start right back up as if the battery was fully charged. When I informed my mechanic he said it could not be the new VRO pump causing the problem.
Instead of taking it out on the ocean again until I was sure it was running right, I took the boat out on a local lake yesterday. It would only run at running rpms for about two to three minutes at a time and the same thing would happen and the motor would just quit. Finally it got to the point that it would start and run at slow idle in neutral, but would die as soon as you put it in gear. I had to go back to the launch ramp with my kicker motor.
I took it to my mechanic. He did a compression test and we were both surprised to see that there was not compression in one of the four cylinders. When I blamed the new VRO pump he assured me that that could not have caused the problem. In fact he mentioned that he had installed the } on the motor. ??????
Does anyone know whether or not the new VRO pump could have caused my problem? I guess the only option I have left is to rebuild the engine.
Any advice would be appreciated.
Thanks,
John"
Thanks,
John"
