VRO sytem
mcc9331
I have a 1992 evinrude 150. Serial number VJ150EXENC that had the VRO system removed.
I want to put it back on the engine but wanted to hear from u guys about the system.
It was working fine but the tech took boat to when I first bought it said I needed to remove.
It’s just a pain to mix the oil to gas and is so much easier to just keep the oil tank full.
Suggestions????
It's a common belief that the system was bad and should be deleted. I however disagree, especially with a built in fuel tank. Over time you may end up with a blend of unknown ratio. Now if you're running a 2 or 3 cylinder engine with portable tanks, the correct fuel mixture is simple to maintain.
A new OEM VRO will last 30 years with non ethanol fuel & quality oil.
Be sure to go thru the whole system from anti-syphon valve to the engine & oil tank/hose.
