Hi
I have a Jonhson 40hp 1996 model
I want to use the vro pumb only with mixed gas with oil
I had read I have to disconnect the cables for the alarm leds, disconnect and close the oil supply, and mix the gas with 1% oil
1) Is that correct?
2) Will the vro pump work ok with no oil sypply, or it will blow out? because the service men in Greece say that the vro pump will fail because the pump was lubricated with the oil supply, and they must put a gas only pump to do the job
Is this correct or they lie?
Do you suggest to do that or leave vro as it is?
Thanks in advance
1) Is that correct?
Thanks in advance
