stonewall65
"Does anyone know if the Oil p
"Does anyone know if the Oil pump piston and linkage for 1998 VRO units has been replaced by a newer version which is slightly longer than the original piston?
Here's the long story leading to that question:
I recently rebuilt the VRO on my 1996 150 Johnson. Having bought the boat second-hand, I found upon inspection that my VRO was a later model than my motor. After replacing the seals, diaphragms, and washers in the repair kit, I reassembled using the original oil piston, which had a worn, blue o-ring seal. The motor ran fine on water at the house, for about 10 minutes with no warnings or issues.
I took the boat to the river for a load test, on the trailer everything again checked out fine, light smoke in exhaust seemed to confirm that oil was present. As soon as I backed off the trailer, the "no oil" warning sounded. I shut down the engine. I checked all lines, reservoir, and found no restrictions to oil flow. Restarting provided the same results, so I shut down, winched up, and went home.
Relieving the fuel from the carburetors confirmed that there was little or no oil in the fuel. I took down the VRO again, carefully re-checking all components against the most accurate diagrams I could find, everything was correct. However, the oil piston seemed to be less than a snug fit, and I felt that it could be failing to produce a vacuum on the negative stroke. I ordered a replacement, according to the part listed by BRP. When I attempted to install the replacement piston and linkage I found it to be at least 1/16th longer in total than the original equipment. Although I have now installed that part, I am concerned that the length of this part will prevent that piston from moving far enough to bring oil into the chamber, and I will have the same problem, again. Obviously, I will run my next test with a premixed remote tank to avoid engine damage, but I am also concerned about damage to the housing for the VRO, which ain't cheap(as nothing that comes from BRP ever is). Any mastertech knowledge would be greatly appreciated."
