VRO fuel side leaks bad...
joem01
Can anyone suggest a direct replacement for a 1990 J70TLESB (70hp) Johnsone VRO fuel pump? The oil side has been abandoned sometime ago and worked fine and now the fuel side is leaking badly and the pump needs to be replaced. Any BRP or Sierra model numbers for a NON VRO fuel pump that's compatable? Thank you kindly...
Just order a pump for a 1983 model 70 HP motor and install it ----------------Remove pulse limiter and install a regular fitting.--------Just did one last week.---------------Bit of plumbing with hoses as well.-------------------Plenty of those ( used ) pumps around at dealers as well.
when you say remove pulse limiter and install a regular fitting. is the pulse limiter a special fitting that i can replace with a regular fitting?
