Thanks much. Yea, at least its not a mercury.
No comment!
This will be, pull a part, clean or replace. Plan on all doing new seals.
All seals can be replaced without the need for re-shimming IF you know what you're doing... and we can walk you through this.
bad corrison, salt water boat.
Things to check:
The main suspension fork where the pivot tube penetrates at the lower section.
The Intermediate housing at the same area.
Most definitely replace the water neck fitting.
Use QuickSilver "Perfect Seal" at all O-rings and mating surfaces.
You'll need to build one of my prop shaft bearing carrier puller tools.
