"I bought a 2000 226 Cobalt 5
"I bought a 2000 226 Cobalt 5.7gsi ( 180 hrs ) earlier this year. The local dealer "checked " it out and did the annual service at that time ( including new fuel/water seperator filter). After the second trip out I noticed the "whistling" sound in the fuel pump that others have mentioned .The Pump also felt a little bit hot but I'm not sure how hot a properly functioning fuel pump should feel.I suspected some water in the tank . I replaced water seperator and it still made the same noise. I emptied it again and the noise stopped, only to return after about an hour of operating the boat. The boat runs fine . I have emptied the filter about a dozen times , usually it stops the noise , for a while. .The boat always runs fine,no missing,etc.I have run the boat for several hours with the whilstling noise and the pump has never overheated.Could this be related to the anti siphon valve or signs that the fuel pump is on its way out?"
