VP drive shaft bearings
Stbury
I have. 1975 VP 280 with a 302 Ford V8 engine
I need part numbers and procedure to change gimbrel bearings Any help will be appreciated
There is no gimbal bearing used in the 1975 VP 280 with a 302 Ford V8 engine.
You have an AQ series drive that will have a PDS (primary drive shaft).
The Ford engines use a single bearing PDS with a pilot nose on it.
The single bearing PDS can be removed from AFT without pulling the engine.
You will need to remove the transmission ONLY.
Use OEM O-rings only.
The s/p drive requires 30W engine oil.
