"My Volvo Penta 5.7 I/o about
"My Volvo Penta 5.7 I/o about 2 years ago would not start. Boat was on the trailer with stern drive in salt water. When the engine would not fire, I turned the key back to "on" and the motor ran backwards ( my dad referred to this in his generation as "dieseling - I know this was not due to a hot spot) and the engine cylinders filled with salt water. It hydrolocked but I did not know this, the starter motor burned up while trying to start the engine, and 1 week later the new starter motor would not turn over the engine. The salt water sat in the engine for a week and destroyed the motor. I was 1 month out of the 2 year repalce everything, no questions asked.waranty. $6000 later I got the boat back thanks to some help from Volvo and a new long block. Now fast forward to today. Again the motor would not fire, except when the key was turned from start to on. Then it "dieseled" again, spinning in reverse and belching vapors from the air intake/spark arrester. Fortunately I found a very knowledgeable mechanic who immediately diagnosed the problem as an ignition switch that had "bridged" due to moisture - what ever that means - and was only sending a spark at the moment of turning the key from start to on. This is exactly the same behavior I experienced before. This time there was no salt water, no hydrolock as when the serious dieseling happened I did not have the garden hose on with the Mickey Mouse flusing ears.
I have two questions:
1) why would the local mechanics and the Volvo Penta VP of Technical support not be able to diagnose the ignition switch isssue - is this so rare? and 2) no one has been able to explain why when the motor ran backwards for a short time it filled with salt water.
the new mechanic keeps ignition switches in stock and tells me he replaces them all the time.
Hope others can benfit from one expert and someone can solve the mystery of the hydrolock. I'm sure Volvo Penta tech services could benefit from what seemed to be impossible. Thanks"
