Pantherman777
REGAL 2200- Built 2008 - had boat for a year now. No issues until now- Ran fine the last 20 times we were out.
Didn't use the boat for about 2 months- stayed on dry rack storage but started it up every couple weeks.
Stainless prop- Checked out at prop shop- Everything is good. We thought spun hub but nope!
I throttle down to go- the boat lags and pushes water- The Rear end goes down and the bow up. It takes its time getting up to speed with full throttle down. Once on Plane the boat flys and everything seems to be fine.
i'd say the RPMS are normal- close to 3K to get on plane then 4/5K when just cruising. (i didnt really want to push it with the engine bogging down or not acting right)
The issue is no low end power and probably cant pull a tuber or skier up because its taking to long to get up to speed.
What issues or items should I be looking at to correct this problem?
Thank you to everything for their input.
