"Hi Bob
Just to jump in on
"Hi Bob
Just to jump in on this disucssion. I have been doing a lot of research into this issue having just aquired a boat with the same basic 1985 Aquamatic 280 leg as you. i.e. one without power trim.
If you only have the elctric tilt, i.e. the most basic configuration and not the hydraulic trim package, then once the drive is out of the locking mechanism called a "retaining pawl" for "leg full down", i.e. your tilt light is illuminated on the dash, then it is only the fragile tilt motor arm that is supporting the drive unit's weight and forward thrust. This means that you can not use reverse reverse, only forward thrust is possible at idle but nothing more. Anything more than idle revs will put too much strain on the electric tilt mechanism and damage it. The mechanism uses a very small arm to tilt the drive that is not designed to work under heavy load.
I would suggest that you invest in a hydraulic trim package upgrade which would allow you to use forward and reverse power (the same as a mercruiser leg) whilst having the drive elevated
Your Volvo Penta dealer will be able to advise if there is a simple upgrade package available, or whther you need an exchange leg. I know that power steering packages are available as a retro fit to the stock 280, but I am not sure if hydraulic trim is available without upgrading to a 280B leg from a stock 280 leg.
The basic differece is that there is an electric tilt motor only on the 280 and there is a hydraulic trim system on the 280B. The basic 280 leg only has the electric tilt motor used for lifting the leg clear of the sea-bed but NOT for trimming the boats nose up or down etc.
The previous owner of my boat got this wrong, having just changed from a mercruiser sterndrive to this boat, and ended up with a £ 3550.00 repair bill as a result of damaging the universal joints and smashing them into the bell housing, behind the transon shield, which meant that the watertight bellows could not be refitted.
This resulted in the engine being taken out and a new bell housing and UJ assembly being fitted!!
This lack of trim facility was a suprise to me too, when I bought the boat, having moved across from a boat with a mercruiser alpha 1 leg.
Let me know if you find an upgrade package.
Regards
Dan"
