1980 Bayliner Explorer
Volvo Penta AQ120B
270 Outdrive
I picked this boat up this summer and it has been a great teaching experience for my children on setting points, rebuilding carbs, impellers and the general joys of boat ownership. I also taught them to ski and when it was finally my turn to show them how it was done the boat lost power to the outdrive after pulling my up. Any thoughts or advice on how to narrow down the issue are greatly appreciated. I’ve scoured existing threads and come up with a few questions based on what I’ve read so far.
Background:
Question 1 – I’ve read about the eccentric piston and making sure that is working but don’t really understand it. It looks like a (fixed) mechanical device that pushes a cone up/down. I’m not sure how to trouble shoot it. Steps for how to identify an issue here are appreciated. The fact that no noise is emanating from the stern drive is making me think this could be the issue.
Question 2 – if I blew the u-joint I wouldn’t it clank or otherwise make some noise? It doesn’t look like there is enough room for non-interference fit
Question 3 – could I pull back the drive bellow to see a spinning shaft to conclusively confine the issue to the upper gears (remove “coupler” from as potential source of problem)
Volvo Penta AQ120B
270 Outdrive
Background:
- Engine runs great but the throttle no longer engages the drive at all in forward or reverse (previously worked as expected did though with a clank I attributed to idle speed)
- Shift cable mechanism looks good (cotter keys there, responds to throttle movements in both directions)
- There is a “bell housing” at the back of the engine that meets at the transom so I cannot see the “coupler” I’ve read about
- There is no noise, resistance, really any indication I’m trying to engage forward or reverse
- Propeller doesn’t move at all on dry land, it isn’t a spun prop
