"Hello EL and all else,
I
I am trying to upload some photos here to show what I'm workin with. I don't now if it worked.
I checked to raw water supply hose and it is tight. I installed it best I could when the outdrive was off. Here is something new, this last time running it I noticed that the boot that links the exhaust manifold to the exhaust pipe leading out was leaking water runing at higher RPMs 2500 - 3000. . what would be causeing back pressure or a restriction in the water escaping from the exhaust at higher RPMs. I say this becasue when I am at idle it doesn't leak. So I tightened the heck out of it and will run it again Saturday.
I am changing the heat exchanger this weekend to see if that will stop the overheating problem. Oh (for anyone new to my problemo) if you didn't know I'm having an overheating problem with my motor when I try to get up on plain. It runs fine at idle, temp. levels off but when I throttle up the temp begins to creep up and when it's in the water with a load it really heats up quick and if I do not back down it blows a freeze plug}.
Does anyone think that the thermostat has to be in? The guy I got the motor from cut the valve out so water runs through it continuously. I'm in FL. Some motors have to have a certain amount of back pressure to run properly.
Pictures I think are attached.
motor pics"">
outdrive
I
