I have a 05 235 Bayliner with a Mercruiser 5.7 Vortec engine. Recently the motor started running poorly and a compression checked revealed no compression on cylinders 4,6, and 7. Pulled the valve covers and was able to get it running by adjusting the valves. However, I couldn't adjust the valves what I consider the proper way (remove lash, and tighten extra 3/4 turn). I ended up having to adjust the valves by ear with the motor running. The motor is running fine, but I'm concerned about what caused this problem and future big time damage.
I pulled the intake and verified that it has roller lifters. When adjusting the valves and watching the lifters, it appears the lifters are pumped up all the time and are not compressing. The engine is sludge free but the lifters don't appear to be compressing. Has anyone come across this before and is there a different method to adjusting roller lifters on a 5.7?
Thanks in advance for any and all replies.
