moresparks
I noticed at the end of the season the sterndrive would not hold trim and sure enough on checking the trim oil I have water in the oil.
I have the drive completely off for usual maintenance so have access to the trim cylinders. On testing the trim without the drive the starboard cylinder moves o/k but the port cylinder does not move at all. If I remove a blanking screw from the cylinder then the shaft will move o/k so it’s not jammed. Although I have a seal kit, am I wasting my time in view of the one cylinder not moving at all? Many of the pipes, hoses and end fittings will not budge. I am currently soaking the end cap fitting in a penetrating oil solution but it seems to be stuck fast. The next step is to find an extension to my pin wrench or possibly try heat; can anybody suggest if this is a good idea? I am trying to replace the seals in situ. Otherwise I may have to remove the whole kit but that looks just as tricky.
I have tested the pump with a new spare and the pump looks good.
Volvo do a complete ram and hose kit (at a price) and was wondering in view of one cylinder not moving at all, replacing was the sensible way to go.
I am not happy about spending the money as I was thinking of upgrading next season so an experienced view would be appreciated.
