Volvo Prop Question
martiniaz
"I have a Volvo-Penta 5.0L OSI
"I have a Volvo-Penta 5.0L OSI/XDP o a 2005 Four Winns 248 Vista. I would like to buy an extra set of props, (others will go in for repair this week and don't want to be stranded over the 4th) but cannot find any information on what the replacement would be. The boat is in the water, so I cannot find the number on them. Four Winns lists it as a F3. I would like to have the spare be composite.
Any help?"
F3 is a code# that Volvo assig
F3 is a code# that Volvo assigns to a set of
props for use on a dual prop outdrive. Contact
a Volvo Penta dealer (if your in the Southeast
call Superior Diesel 800-662-7953) give them
the F3 code and they'll be able to look up the
prop set based on code. The props are generally
numbered in the center hub area of each prop.
Prop part #'s generally start with "385####"
Thanks Scott. I ended up just
Thanks Scott. I ended up just pulling it out of the water and removing them and found it to be exactly as you said.
