Volvo Penta SX drive
gt40
I have a late model SX drive p
I have a late model SX drive probably 4-5 years old and it is leaking oil from around the propshaft. I have taken out the small retaining grub screw and the retaining bolt inside the drive. I was wondering if the bearing carrier just pulls out to replace the seal or is it screwed in?
"I'm having the same probl
"I'm having the same problem with my SX drive. I changed the oil in the drive last night, and when i removed my injection line from the bottom drain hole, about 2 OZ of water drained out before the first drop of oil...I guess i need to pressure test it for leaks? Is there a special air fitting that fits the threads for the oil plugs?"
"Can anyone tell me what stern
"Can anyone tell me what stern drive is on a 1989 volvo penta AQ231a engine. The stern drive is a duo prop....is it a dp or sx and is it a 250, 270, 280.....thanks"
"Julio - yours is DP, but to g
"Julio - yours is DP, but to get more specifics, you need to find the engraved serial and model number on the nameplate affixed to the drive. There may also be a sticker on top of the circuit breaker enclosure of the wiring harness. It will tell you which model DP and the gear ratio."
Thanks alot...now I just have
Thanks alot...now I just have to figure out what model this thing is (280 or 290) the plate on the drive is rotted out all I got off of it was DP-A and the numbers 195 what I specifically need to know is what model suspension fork I need anyway I appreciate your help.
