"Took the boat out for the fir
"Took the boat out for the first time. Boat overheated within 10 minutes. Found that impeller had about 1 1/2 blades missing. Found round tips in drain plug on manifold. Bigger pcs. not found. I replaced impeller and still had it overheat. Next I back flushed the lower unit intake, flushed the thermo housing, flushed the manifold. I also replaced the thermostat, heat sender, heat sensor, and tested the exhaust heat sensor.
It is still overheating. Any other suggestions? Thanks in advance for any advice you have!
Dano"
Dano"
