Volvo penta outdrive
"Ah, is there a question here?
"Ah, is there a question here? Fix it!
(hey, someone had to give you a S/A answer!)
Which drive/which hose/or is this a fitting that is leaking?
Some of the early cylinders develop corrosion at the cylinder end housing that will cause the fitting to lose it's tight connection.
Better check this out.... it may involve removing the cylinder.
Heat this area slightly before attempting to remove the fitting.
one of the hydraulic hoses fro
one of the hydraulic hoses from the cylinder to the stern has small leak at the stern. Looks like compressed fitting is leaking. Looks easy to replace. I need replacement tips and type of hydraulic fluid
