Hello, I have a Volvo Penta that needs a major overhaul. The uploader is giving me errors so here is a link to the album: http://imgur.com/a/QDksM
First thing is the intake manifold. With rust accumulating around the manifold. Is safe to dissemble,clean and replace the gaskets or should the whole unit be replaced.
The U-joint is completely rusted. I'm assuming this has to be replaced and is unsalvageable
Water ports have a lot of white crusty build-up. Any tips or perhaps a solvent that helps with the cleaning.
The gimbal bearing and bellows will be replaced. With this level of wear is there anything else that I should look out for.
Thanks you for your advice in advance.
