We have always had a steering issue on this boat and wondered if anyone has experience on diagnostics on this. When underway the steering springs to PORT very aggressively and you need to really use a lot of force to keep it straight and even worse to turn it Star Board. We did a test as follows . First test on dry dock. Disconnected the linkages to the Stern drive and checked the cables, all fine and very smooth lock to lock. Moved the stern drive and that too moved from one side to another with no effort at all. Then turned on the engine on dry dock and did the same. Seemed harder to steer with engine running than with the engine NOT running. We then launched the boat in the water and ran the engine at idle in neutral. Its harder to turn lock to lock with engine running than it is when engine is OFF. Checked the reservoir and oil is fine, checked the bilges and joints of all pipes and not a drop of oil anywhere, opened one of the high pressure pipes when engine running and oil does come out of the hose. Checked the cooling tube and no oil and water mixture there either. Can the ram be defective on a 4 year old boat with just 25 hours?? Any other tests to isolate the problem of a faulty RAM or a pump not giving enough pressure, air lock. You literally can not leave your hands off the steering at any speed on this boat. Skegg is fine , no other adjustable trim either. Thanks
