Its a Rodman 810. The port engine fires up and runs fine.
Starboard engine nil effect when I turn the starter switch not even a slight click from the starter solenoid. Initially I suspected the starter solenoid.
I stripped out the starter and put it on the bench. 12V on the terminal then when I put 12V onto the solenoid it pulls in and runs fine.
Starter and solenoid seem fine.
Next checked wire that attaches to starter solenoid. 0V when starter switch is turned.
Below the console I took the wire to the solenoid off and checked the switch terminal. When in start position there is 12V on the terminal BUT the 12V is not getting to the starter solenoid.
Next did continuity check from switch terminal to starter motor solenoid terminal – open circuit.
So the cable from the starter switch to the starter motor solenoid has a break but where?
Is there a micro relay somewhere in the circuit or is the cable a continuous run from the console switch to the starter motor solenoid?
Could a new cable be run direct from the switch to the starter motor terminal?
Any suggestions appreciated
Dave
Dave
